Retired_Member's avatar
Retired_Member
Mar 05, 2017
Odd result in debug menu - Flash (R8500)
Will keep this simple.
When I log into the debug page at http://routerlogin.com/debug.htm I receive the following info regarding the flash storage:
Flash Usage (Used/Total) 195.66MB/251.10MB
The surface problem is that in the data sheet the router comes with 128 MB of flash storage. This is showing more storage in use than the router should even have. Wondering if this might indicate a bigger problem in the background?
  • Memory size is 128MB
    This is just a bug on the debug page.
    It is just a display issue and does not impact router functions.
1 Reply
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
