JimmyW
Jul 19, 2023Luminary
Odd speed tests
My ISP is Cox, and I'm on the 500 Mbps/10Mbps plan. When I run a speed test on the 2.4 band, it shows only about 50 Mbps d/l. If I check the d/l speed with the Nighthawk app on my Android phone, it ...
- Jul 19, 2023
You'll not see speed on 2.4Ghz anywhere near 500Mpbs. Due to limitation of the frequency and configuration and design of wifi devices, most you may see is around 200-300 depending on wifi device design and support.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.htmlThat's good speed on 5Ghz though.
Jul 19, 2023Guru - Experienced User
JimmyW
Thanks! Yes, I hit about 300 Mbps d/l on the 5.0 side. I generally use the 2.4 as I'm often outdoors on my patio, and the 5.0 doesn't handle walls very well.
