emoze-2's avatar
emoze-2
old password & SSID for disconnected N600 connects on new AC1900
my N600 DGND3700 was replaced 6 months ago by a newer Nighthawk AC1900;  the 2 units have different SSID's & passwords yet i can still connect to the AC1900 from iPhone & iPad using the old N600 pass...
  • emoze-2's avatar
    Feb 09, 2024
    SOLVED
    turns out the old DGND3700 SSID and password were saved into my TP-Link 8610 ethernet/wifi powerline device when i used the WPS button process for setting it up long ago - so the netgear info registered into the TP-Link device 2.4GHz channel - it was then possible to log into that device which was ethernet connected to the new Netgear D7000 DSL router.  I recently ditched Netgear & DSL in favor of a new ATT Internet AIR setup - the old netgear login still worked via the TP-Link; .... finally i used the TP-Link tpPLC software to discover the old netgear info was still there ... reset the ssid's & passwords - old Netgear ghost  is now gone forever
    (p.s., the ATT AIR device is amazing  - 100Mbps downloads vs the old ATT DSL that never bested 2.4Mbps)
