ourgang309
Jan 23, 2017Aspirant
Old router network showing up on new router network - Nighthawk R7800
Hello - looking for some help. I recently purchased a new Netgear router to replace an older model. I set up the new using the same network name as I used with my last. We created a new password f...
- Jan 31, 2017
Hello all - found the souce of the issue. The cable modem had a wifi network built into it that I had set up a long time ago, before I got the new router. That is the source of the networks that we don't want active. I have been able to disable that fuction on the modem while keeping my Netgear router active. Thank you very much for the time and ideas that helped us figure it out. Thanks!
Jan 25, 2017Guru - Experienced User
Try installing WiFi Analyzer or the Netgear WiFi Analytics app on the android phone.Both can scan and show you the networks that still exist.
If the old networks show up on those scans, then we'll need to find out where the transmitters are.
ourgang309
Jan 26, 2017Aspirant
Good morning - I have the wifi analyzer installed on my phone and did get a good signal read on both the Russell3092 and Russell309_EXT network names that are not supposed to be there. Regarding the transmitter, what are the suggested next steps? As I mentioned before, the old rounter and the old extender are not plugged in or powered on so what could be sending out that signal if not them? Appreciate the help on this very much!
