feipoa
Apr 26, 2025Tutor
Older Windows PC's no longer see networked drives w/ R7000 when using firmware v1.0.11.216 or newer
I noticed that there were some serious security vulnerabilities with the R7000 router, in particular: CVE-2022-48196 CVE-2022-37235 CVE-2022-37234, for which a cyber attacker can use a technique ...
feipoa
Apr 26, 2025Tutor
I posted the same question in another forum and someone mentioned that Netgear probably disabled SMB v1 on the latest Netgear firmwares, however it might be possible to re-enable SMB v1 through the firmware's config files. Does anyone know how to do this?
Alternately, could Netgear please re-release the firmware with SMB v1 re-enabled, or at least make it a toggle switch to the end user in the UI? Thanks.
Apr 27, 2025Guru - Experienced User
the R7000 is a 12 year old router. It was released in 2013. Its been on the end of life bulletin for a while. So you aren't going to see much development/changes with it.
Your best option? The r7000 was one of the devices that could run 3rd party firmware like ddwrt/tomato. they still get updates/development and in certain cases, work extremely well. Might be an option if you're wanting to continue to use an ancient router.
- feipoaApr 27, 2025Tutor
The latest firmware for the R7000 was released just a few months ago, so unless another critical vulnerability is discovered, I'd imagine the router has some time left on it.
I don't think a new router will resolve the issue with older computers not being able to access the NAS. I would imagine that all new Netgear routers now have SMB v1 disabled, thus buying new won't resolve my issue.
At some point, I may look into a 3rd party firmware, but there exists the risk of ruining the router entirely.
- plemansApr 27, 2025Guru - Experienced User
You always always try enabling/disabling on the pc
