icplaytherapy
Nov 06, 2024Follower
One Device Won't Connect to Nighthawk
Nighthawk AC2300 Smart WiFi Router - Model R7000P We have had this router for over 6 years now. We've never had an issue with connecting to the internet. We have one device (a Dell laptop) that has ...
Nov 06, 2024Guru - Experienced User
whenever its a single device with issues, it makes me suspicious of the device and not the network.
Might try a simple wifi usb adapter and see if that works. If it does, you could always try replacing the internal card or keep using the usb one
JWS9518
Nov 07, 2024Luminary
I agree with Plemans, it could be the failure of your wi-fi and/or network port on your laptop.
If you have a network port, you could try hardwiring into the router to see if there is a connection and to check for updated drivers for the wi-fi and/or firmware for the laptop, as it possibly could also use a bios update that might possibly help as well.
If that fails or not possible, then I have the same suggestion to get a wi-fi adaptor and try that.
