James95757
Feb 10, 2022Follower
One of my laptops can't see my 5G connection.
My AC2000 wifi router comes with two WPA2 connections. We have five laptops that are able to access both connections. The first connection is factory named Netgear 70, and the second is Netgear70 ...
Kitsap
Feb 10, 2022Master
Your Netgear 70 connection is on the 2.4 GHz band and your Netgear 70_5G connection is on the 5 GHz band.
Is your Wi-Fi radio and hardware on your 6th laptop capable of connecting to the 5 GHz band? Usually when the 5 GHz SSID's don't show up in the connections list, it is because the hardware is not capable to connecting to the 5 GHz band.
