pardeezyy
Dec 10, 2018Initiate
One Wired Connection Creates Internet Solid Amber Light
I have a R6700v2 that is driving me up the wall. This morning, I received a solid amber internet light after 13 months of no issues (conveniently 1 month ouside of the warranty window). I found that ...
- Dec 10, 2018
> When I plug in the other wired connection, which is connected to a
> switch that powers 7-8 devices in my media console, the internet light
> turns a solid amber and all the wired and wireless devices fall.
And you blame the router, not the (unspecified) "a switch" plus the
"7-8 devices" for this problem?
> [...] I've tried connecting that ethernet cable to every single port
> to see if it's a hardware issue on one particular port. Didn't resolve
> it.
"every single port" of _what_? The router? See "And you blame
[...]", above.
If connecting your device-laden (unspecified) "a switch" to the
router causes the problem, then I'd start disconnecting devices from the
switch (followed by the switch itself) to see which of those devices is
disrupting the router's operation.
antinode
Dec 10, 2018Guru
> it.
[...]", above.
