mcguire6799
Oct 31, 2016Tutor
Only getting 100mb/s download
I upgraded my connection for my internet from 50mb/s download to 1GB (ISP says it will vary between 350mb/s-1gb/s depending on their fiber equipment at my house.) I speed test today after they upgrad...
- Nov 09, 2016
mcguire6799 wrote:They are coming out today to take a look at the connection speeds they are seeing. They are now saying it may be a 300up/down card anyways and I was promised speeds excess of 350mb/s. Kind of irritating to hear that but hopefully by today it is fixed.
They gave 2 possibilities... 1) Break in the connectiong at the wall jack. 2) Break in connection at the box where the fiber comes in.
Or... CAT5 cabling in the wall, as opposed to CAT5e, or higher..
mcguire6799
Nov 01, 2016Tutor
I tried the cable not because 5e won't handle it, just to eliminate the cable as an issue. My ISP has the port setup for a router on their end, they would have to set it so my PC could grab the IP. They see it on their end as only communicating at 100mb/s.
Retired_Member
Nov 01, 2016you can test the router WAN port
jump wan to lan and reboot.... wan port LED should turn white and statistics should be 1000M/Full
- mcguire6799Nov 01, 2016Tutor
Currently as it is setup the WAN LED is white. I will jump the WAN to LAN after work this afternoon and see what it does.
- Retired_MemberNov 01, 2016
Give them the Wired PC MAC address.....and when setting up the router ...in setup internet setup.... select USE PC MAC and use same pc to setup router.
I'll see what I can get accomplished after work. So go ahead and factory reset the router and use the MAC address of my PC?
