mcguire6799
Oct 31, 2016Tutor
Only getting 100mb/s download
I upgraded my connection for my internet from 50mb/s download to 1GB (ISP says it will vary between 350mb/s-1gb/s depending on their fiber equipment at my house.) I speed test today after they upgrad...
- Nov 09, 2016
mcguire6799 wrote:They are coming out today to take a look at the connection speeds they are seeing. They are now saying it may be a 300up/down card anyways and I was promised speeds excess of 350mb/s. Kind of irritating to hear that but hopefully by today it is fixed.
They gave 2 possibilities... 1) Break in the connectiong at the wall jack. 2) Break in connection at the box where the fiber comes in.
Or... CAT5 cabling in the wall, as opposed to CAT5e, or higher..
mcguire6799
Nov 03, 2016Tutor
Router is now using my PCs MAC address and same issue persists. While on the phone with my ISP they confirmed they are transmitting at 1000m but I my router is only authenticating at 100M. While it is using my MAC address of my PC I plugged it into the wall to see how it acted. It tries to authenticate, drops connection before grabbing an IP, and then attempts to authenticate a few seconds later. And it does this repeatedly.
ElaineM
Nov 04, 2016NETGEAR Employee Retired
mcguire6799 What's the speed if you connect your computer directly to the modem or the box that connects directly to your ISP?
- mcguire6799Nov 04, 2016Tutor
Comes straight into the RJ45 in the wall. From the fiber converter box in the garage to the jack. When I plug into the RJ45 jack on the wall my computer won't grab an IP, it attempts to authenticate then drops before grabbing the IP. The router into the wall works fine, and my PC into the router works fine.
