rbarcia9
Jan 02, 2022Aspirant
Only power light is on
Hey all. Happy New Year's. I was wondering if anybody knew or had a similar experience. For my extender, I only have the power light on. None of the other lights are on meaning nothing else works. Tha...
rbarcia9
Jan 03, 2022Aspirant
The power light is a steady green light. I'll try those options you gave me. I use my phone for setup.
Jan 03, 2022Guru - Experienced User
If the factory reset doesn't work, start with trying to hardwire a pc/laptop into the extender first.
factory reset: push and hold reset for 7-15 seconds while powered on. The lights should blink/change when held long enough.
disable the laptop/pc's wireless. then connect it and try to access the mywifiext . net or its default 192.168.1.250
