Inetwl
Feb 22, 2021Aspirant
OOTB Device name part of SSID broadcast affter reset
I changed the name of my NETGEAR device, and changed the broadcast name for the SSID. The name "NETGEARxx" is no longer displayed anywhere in the Genie app.
Now, when I connect my Wi-Fi adapter and then look at Network Connections (on Windows 10), I see the original, out-of-the-box name for the device. Where did it come from, and how do I change the name so that NETGEARxx is not displayed on other devices?
Inetwl wrote:
I changed the name of my NETGEAR device...
And that device is?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device. > [...] Network Connections (on Windows 10), [...]
That's a Windows question, not a "NETGEAR [unspecified] device"
question.> [...] Where did it come from, [...]
Presumably from an initial/default SSID on your (unspecified)
"NETGEAR device", before you "changed the name of [your] NETGEAR
device".> [...] how do I change the name so that NETGEARxx is not displayed on
> other devices?I do approximately nothing with wireless on Windows, so I know
nothing, but I'd probably try to delete that existing Network
Connection, and create a new one for this (unspecified) "NETGEAR
device", specifying its new SSID.
