achan000's avatar
achan000
Open VPN not work on Windows 10
Hi support,   My R7800 open VPN did not work after upgrade to firmware 1.0.2.52. Error message as below, Sat May 26 13:39:41 2018 WARNING: No server certificate verification method has been ena...
  • JamesGL's avatar
    JamesGL
    May 31, 2018
    Hi achan000,
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
