achan000
May 25, 2018Aspirant
Open VPN not work on Windows 10
Hi support,
My R7800 open VPN did not work after upgrade to firmware 1.0.2.52. Error message as below,
Sat May 26 13:39:41 2018 WARNING: No server certificate verification method has been ena...
- May 31, 2018
Hi achan000,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
TerryPh
May 25, 2018Virtuoso
Did you try to rest the router after FW uodate?
achan000
Hi,
I tried to reboot the router and got same result. Only my iphone can connect open VPN.
- TerryPhMay 25, 2018VirtuosoDid you physically turn off the router and turn it back on? Hard reset, I mean..
If not, try it .
Please let us know how it works after the hard resetting- achan000May 26, 2018Aspirant
It worked find after hard reset. Thanks for help!
- JamesGLMay 31, 2018NETGEAR Employee Retired
Hi achan000,
- nep01Jun 01, 2018Aspirant
I got same problem
same hardware R7800
same firmware 1.0.2.52
same os windows 10 64bit
I turned off/on the router (power off/on) but it still no work
that's it:
Sat Jun 02 04:41:48 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
how can I do? thank you~
router DDNS is OK
and I also renamed ethernet to "NETGEAR-VPN"
my openVPN software version is 2.4.6-I601 64bit by the way~
- schumakuJun 04, 2018Guru - Experienced User
Downloaded the new OpenVPN config package from the router, and set in place on the Windows 10 OpenVPN client?
If this does not work, try a factory reset (UI, reset button), and re-config the router manually from scratch - and download the now recreated OpenVPN config package again.
