achan000
May 25, 2018Aspirant
Open VPN not work on Windows 10
Hi support,
My R7800 open VPN did not work after upgrade to firmware 1.0.2.52. Error message as below,
Sat May 26 13:39:41 2018 WARNING: No server certificate verification method has been ena...
- May 31, 2018
Hi achan000,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
achan000
May 26, 2018Aspirant
It worked find after hard reset. Thanks for help!
JamesGL
May 31, 2018NETGEAR Employee Retired
Hi achan000,
