Talls79
Jan 03, 2018Aspirant
OpenDNS and PIA VPN together on iPad
Hi, i'm looking for advice on how to do the following -Use OpenDNS setting on router to keep family filter on -Use PIA VPN on an end point device (iphone, ipad) for VPN use occasionally Note I'...
- Jan 03, 2018
Since OpenDNS is effectively filtering your traffic, it may be set up to block VPN connections, but that's just speculation. It's hard to say since both OpenDNS and PIA are specific products that the rest of us don't necessarily have access to for troubleshooting. If you're convinced it's a router issue and not an OpenDNS issue, check your security settings, particularly with regards to blocked services.
tlmassey
Jan 03, 2018Apprentice
