blrn5
Dec 20, 2021Follower
OpenDNS parental control going away?
I have read that support for Netgear OpenDNS parental control is ending 12/31/2021. Does that mean it will no longer work on my r8000 Nighthawk router after that date - please can someone clarify wha...
microchip8
Dec 20, 2021Master
Future firmware versions will remove//deprecate OpenDNS parental control. NETGEAR is removing less used features in a lot of models to make space for services it can sell you (whether you like it or not). If you're so dependent on OpenDNS PC, do not upgrade to newer versions that remove it
