Jfossy
Nov 01, 2017Guide
OpenVPN 1.1.22 Android
Ever since The Android app of OpenVPN updated to 1.1.22 I can no longer connect to my router. It give OpenVPN server certificate verification failed : mbed TLS: SSL read error : X509 - Certificate v...
- Nov 06, 2017
As as update 1.1.24 of OpenVPN Connect has fixed the solution. According to the changelog though, they relaxed the certifaction validation in mbedTLS to allow certificates with broken date format to connect and re-enevabled depricated and INSECURE md5 signature algorithm. SUpport for md5 will be officially dropped on April 31, 2018.
I'm not exactly sure which of the two caused the problem, if it's the later, I hope Netgear updates the OpenVPN server software in the a firmware update before then.
python_1
Nov 04, 2017Aspirant
Jfossy
Nov 06, 2017Guide
