martin51
Oct 22, 2020Initiate
OpenVPN on iPhone fails to import profile for NightHawk R700P
Have been trying to get OpenVPN to run on my iPhone. Download smartphone config files from router to my iPhone. Share client3.ovpn file to OpenVPN but clicking on "Add" to add the profile results in ...
likeabawse
Apr 12, 2021Initiate
I had the same issue and i was finally able to solve it. I dont know what netgear thinks happens when you follow their normal steps, but it didnt work for me.
I had the issue where it couldnt find these files ca.crt, client.crt, client.key. My solution was to create a "unified" ovpn file. The unified file just means that you embed the contents of ca.crt, client.crt, client.key into the ovpn file, rather than have the ovpn file point to separarte files.
This page explains how to do that https://openvpn.net/faq/i-am-having-trouble-importing-my-ovpn-file/
One issue I ran into is I found this sample file as an example to follow https://gist.github.com/renatolfc/f6c9e2a5bd6503005676 . That file is wrong. there shouldn't be any [inline] things:
ca [inline]
cert [inline]
key [inline]
tls-auth [inline] 1
my client_unified.ovpn file looks like this
client
dev tun
proto udp
remote {{domain_name}} {{port}}
resolv-retry infinite
nobind
persist-key
persist-tun
cipher AES-128-CBC
comp-lzo
verb 5
<ca>
{{contents_of_ca.crt}}
</ca>
<cert>
{{contents_of_client.cert}}
</cert>
<key>
{{contents_of_client.key}}
</key>
hope this helps!
alchle
Jul 25, 2022Star
This did not work for me. Same exact situation. I tried with and with out the squiggly brackets {{}}. No luck. Do I literally paste the entire contents of each file, or only sections of it. When i do this i get the message "option_error: option <key> was not properly closed out." I double checked, I do indeed have the </key> (with the slash too). Any other thoughts? Thanks
<ca>
</ca>
<cert>
</cert>
<key>
</key>
- webcurlSep 15, 2022Aspirant
did you every find out what caused this im having the same issue
