derjuden
Mar 15, 2021Initiate
OpenVPN TLS key negotation error
Hello I just bought a client a new R7000 router and setup openVPN. I have a static IP and I setup dynDNS since I was having problems connecting. Both ways give me the same error from a windows mac...
derjuden
Mar 16, 2021Initiate
Okay for anyone reading this I have resolved the problem but now I'd like to know why this setting fixed it. So one thing about this setup that is not factory default except for turning on the VPN is my client got SIP phones from Ringcentral. They made some changes to the WAN setup tab. It appears they set "NAT Filtering" to "secured" from open. I'm not 100% sure what the default is supposed to be. Anyways I changed that and then I got a error about not having a route gateway. Well turns out my problem was that when i upgrade my openVPN client it reset the name of the TAP interfaces to the default and netgears configs are built using "NETGEAR-VPN" changed that and it works.
