bvrijswijk
Jul 14, 2017Tutor
Orange / Red light on my netgear nighthawk router
Hi I got en new Nighthawk and when connecting the ethernet cables i get on one port a red light on the other port the lights are white.(when transfering data) even changing the cable into an othe...
- Jul 15, 2017
althogh the tester did not indicate any problems, a new connector fitted and it works great now.
Problem solved
thank you all
all the best
Be
bvrijswijk
Jul 15, 2017Tutor
Thank you so much for your reply, I am using cat 6 cable but home made connections so yes it can be that the cable has wrong connections.
I will go for a tester and see if this is the problem
all the best
bep
bvrijswijk
Jul 15, 2017Tutor
Problem solved
thank you all
all the best
Be
