farmhof
Aug 25, 2017Aspirant
Orange / Red light on my netgear nighthawk router
My ethernet port on my netgear skyhawk router shows orange/red where I have my arlo base station plugged into .The arlo base station shows a flashing orange light for the internet light. I am not sure what the problem is. Anyone familier with this situation? I would appreciate any help.
No, the base station is connected but I was having trouble with one of my cameras going off line and thought the amber light meant a weak signal. I thought it was suppose to be white. I appreciate your info. Answers my question and Netgear is replacing the camera. The amber light is not the issue. Thank you michaelkenward.
The colour of the ethernet lights is usually an indication of the speed they are running at.
Orange = 100 Mbps Green = 1000 Mbps.
Solved: Netgear Router WNDR4500 port is orange for Arlo ba... - NETGEAR Communities
Are you saying that the base station isn't connected?
- farmhofAspirant
