SteffJay1's avatar
SteffJay1
Follower
Jun 24, 2018
Orange / Red light on my netgear nighthawk router
I have connected another pc to the router and the router is giving the pc a ip address of 192.168.x.x. The pc is working well and is able to get onto the net etc. However, there is a red light showin...
  • Blanca_O's avatar
    Jun 24, 2018
    Hi SteffJay1,
    If the device you connected is only capable of 10/100 Mbps Fast Ethernet LAN connection, the LAN port lights amber to show that it is connected at a slower speed than what is supported by the router. If your device has a Gigabit Ethernet port, the LAN port lights white.
    Blanca
    Community Team
