Meforgiel
Jan 09, 2022Aspirant
Orange light on nighthawk model ax43
Hello! Just set up my router and the internet light is orange (second light right). Why is that and how can i fix it. Thanks
microchip8
Jan 09, 2022Master
Orange indicates 100 Mbps speed instead of 1 Gbps. What's yoour modem? which router do you actually have?
- MeforgielJan 09, 2022AspirantThanks for the quick reply. My modem is from my ISP and there is nothing written on it just a black box.
I just bought and installed the Nighthawk model AX42- microchip8Jan 09, 2022Master
Your title says AX43 but now you say AX42. Which is it?
Most likely your modem operates at 100 Mbps or if not, your cable is faulty or not CAT5e or higher
- MeforgielJan 09, 2022AspirantOops, typo, its a 42 sorry
Whats CAT5e?
