srhsieh
Feb 21, 2020Aspirant
orange light
I just bought a nighthawk smart wifi router R6700-AC1750. After setup, I notice that the front panel led display showing an orange light on the LED labelled '1' (locates between 'USB' and '2'). Can a...
- Feb 21, 2020
Sorry about the post. I think that I figured out the reason after reading the other post.
I pluged in ARLO on the #1 port so it is orange since speed is only 100.
srhsieh
michaelkenward
Feb 22, 2020Guru - Experienced User
Yes. The LED for the LAN ports are colour coded.
100 Mbps = amber
1000 Mbps = white
All in the manual.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
