AtomicAdam's avatar
AtomicAdam
Follower
Nov 08, 2020
Orbi RBR40 Router Performance Capability
I upgraded my internet sppeed to 940 mbps which I obtain when going directly from modem to computer
When going from my OrbiRBR40 it drops to mid 500 mbps no matter the quality of my ethernet cable
Can my Orbi not handle that speed?
Any suggested solutions?
I can be back channled at JacobsAG@gmail.com
Thanks
1 Reply
  • plemans's avatar
    Since the update, did you try a factory reset and reinstall?
    maybe an old setting is causing issues.
