DevB
Aug 31, 2021Aspirant
orbi RBR50 No SSID broadcast
Orbi RBR50 stopped broadcasting SSID, i tried resetting the router, but didn't help. Please help. I can't even login to get Firmware version.
Aug 31, 2021Guru - Experienced User
Whats the power light doing? (color, solid)
What is the led's at the top doing? (color, solid, blinking, etc)
Are you able to hardwire in a pc/laptop to the router and access it?
- DevBAug 31, 2021Aspirant
Solid Green
Blinking White ring
Yes, Modem is working and able to directly connect using my laptop
- plemansAug 31, 2021Guru - Experienced User
If the led at the top is blinking white, it means its in factory default mode and needs to be setup.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Try hardwiring a pc/laptop into the orbi router and going through setup again.
I tried directly connecting to the router using ethernet cable but couldn't connect. So, what is the best way to hard reset or apply the latest firmware? Can I upgrade firmeware using USB?
