JeffLB
Oct 06, 2021Aspirant
Orbi RBS50 wired backhaul setup issue
Hi, I have an RBR50 and RBS50, both running the latest firmware. (2.7.3.22) System has been working well for quite a while using wireless backhaul, but I just put in a wired connection elsewhere in t...
- Oct 06, 2021
Netgear has set up a community forum specifically for the Orbi AC (WiFi 5) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/OrbiThank you.
Oct 06, 2021Guru - Experienced User
Thank you.
JeffLB
Ah thank you - I had no idea I was in a Nighthawk forum. I'll repost over there.
