MacGio1979
Sep 14, 2022Follower
Orbi Router turns magenta when my iPhone is in the net
Hi! It’s so strange. Very evening at ca 21:00 my Orbi Router gets magenta. So there is no internet anymore. When I turn off the Wi-Fi of my iPhone 12 in a few seconds the internet is back and all the ...
Sep 14, 2022Guru - Experienced User
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What iOS are you using?
Do other iOS devices do same thing?
Be sure to disable WiFi Private Address feature on the phone.
