WTFWWIW
Feb 03, 2023Tutor
Orbi v Nighthawk
Hi, which is the better router Orbi RBR750 or Nighthawk r7000p?
- Feb 03, 2023
Orbi.
FYI, the R7000p is much older and also doesn't have newer Wifi 6 support.
michaelkenward
Feb 03, 2023Guru - Experienced User
Better for what?
One is Mesh Wi-Fi, one is not. The R7000P has features that you won't find on the RBR750, like ReadySHARE.
The flashier Wi-Fi 6 thing is nerds wet dream that may be irrelevant to you. So it is down to what you expect of a router.
I have an R7000P in constant use, but it isn't something I'd install now. I go for the RBR750.
