Xenokai
Aug 30, 2016Aspirant
Ordered a Nighthawk R7000, which firmware to use?
I wanna note that I don't have the router yet but its on the way in the mail to me. I purchased it to use with my fiber optics connection that is planned to be installed by the end of the year. I c...
- Aug 30, 2016
AFAIK, there is only one version. My R7000 is over 2 years ago and still going strong.
TheEther
Aug 30, 2016Guru
Asuswrt-Merlin also supports CTF.
VE6CGX
Aug 30, 2016Master
OP, first thing in order is when you receive the router just make sure every thing works fine the way you expected. Then think
about upgrading firmware or trying 3rd party ones. Quite a while back I had R7000, I liked it then with Kong's dd-wrt. ATM,
I am using R7800 or Asus RT-AC3100 with a 8 port dumb switch, while one is on the air, the other one is stand-by spare unit I like them both, very stable routers.
