Xenokai
Aug 30, 2016Aspirant
Ordered a Nighthawk R7000, which firmware to use?
I wanna note that I don't have the router yet but its on the way in the mail to me. I purchased it to use with my fiber optics connection that is planned to be installed by the end of the year. I c...
- Aug 30, 2016
AFAIK, there is only one version. My R7000 is over 2 years ago and still going strong.
Retired_Member
Aug 31, 2016
Xenokai wrote:Just don't wanna get a firmware thats not compatible.
1.0.4.30 ............If netgear had stopped making FW after it, they would had been better off.
RMinNJ
Aug 31, 2016Luminary
I'm still running..1,0.4.30_1.1.67 ...what the router came with.
Its working fine... not sure if I should upgrade to the latest or just leave it alone.
- Retired_MemberAug 31, 2016
In my opinion NG has NO update after 1.0.4.30 but Xwrt-Vortex does.
Almost forgot You'd better start using it NOW! Because if you find out later it sucks you're stuck with it.
