c3collins
Feb 21, 2022Aspirant
Outgoing eMail on Port 587 Blocked - Nightwawk R6700
Since Installed my own modem (Arris surfboard) and Nighthawk R6700 router, I have two email accounts that receive email but cannot send outgoing mail. The outgoing port is 587. I have other email (...
Feb 21, 2022Guru - Experienced User
All email settings would be done at the email client on the devices. Routers don't support any email client configurations nor usually won't interfere with email services. Unless you have Armor or Smart Partental Controls enabled then these could cause some problems.
- c3collinsFeb 22, 2022Aspirant
The firmware version is V1.0.4.122 and the modem is Arris Surfboard SB6190.
Any thoughts would be appreciated.
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?All email settings would be done at the email client on the devices. Routers don't support any email client configurations nor usually won't interfere with email services. Unless you have Armor or Smart Partental Controls enabled then these could cause some problems.
- KitsapFeb 22, 2022Master
Three other things that would be helpful: Who is your ISP? Are you on Windows? (If yes, what version), and what is the name of the client application you are using to access your e-mail?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - FURRYe38Feb 22, 2022Guru - Experienced User
Thanks for confirming the ISP modem and model#. No issues here. Though not the best modem to have.
So email settings would need to be checked on the client device or email app.
Try testing with a different device to compare as well.
