MrScrubsy
Oct 25, 2016Aspirant
Packet loss during gaming with wired connection
Hello, Ever since our family has bought the R7000 I have noticed severe packet loss with a wired connection in gaming. Wifi has no issues with connection with at least 4 devices always connected. Th...
- Retired_MemberNov 01, 2016
Here's mine using WIFI
I think yours could be better seeing it's a wired test correct? The test MEANS Nothing when other users are using network. It Only gets worse.
I meant to suggest earlier that you hook up old router seeing how you said Ever since you got the r7000 the problem started. Also try FW V1.0.4.30 after that I give up.
Retired_Member
Oct 25, 2016When connecting directly to Arris no other devices are sharing the connection. You said, No issues using wireless....Are you saying if you play same games with same device using wireless it works fine?
- MrScrubsyOct 25, 2016Aspirant
Sorry for the confusion. No, i do not have a wireless adapter for my pc, nor any other device strong enough to rightfully test that case. My pc is the only thing wired connecting to the R7000 in the house.
- Retired_MemberOct 25, 2016
Ok,
To rule out other users you'll need to Push the 2nd from the right WIFI off - on button and test. Still bad, disable QOS, still bad push reset until power LED flashes using defaults test again...still bad try V1.0.3.40 fw.
http://www.dslreports.com/speedtest post the test results ( block IP )
- MrScrubsyOct 26, 2016Aspirant
Alright well I disabled the wifi power and that seemed to make a difference right away, although i kinda figured it would due to the fact that the modem wasnt giving a problem either. Now the thing is trying figure out why it would be the wifi that is hounding on the connection so bad. We have the 2.4hz and 5hz enabled when wifi is on.
Here is the DSL test for when the wifi is turned on. And without wifi.
