MrScrubsy
Oct 25, 2016Aspirant
Packet loss during gaming with wired connection
Hello, Ever since our family has bought the R7000 I have noticed severe packet loss with a wired connection in gaming. Wifi has no issues with connection with at least 4 devices always connected. Th...
- Retired_MemberNov 01, 2016
Here's mine using WIFI
I think yours could be better seeing it's a wired test correct? The test MEANS Nothing when other users are using network. It Only gets worse.
I meant to suggest earlier that you hook up old router seeing how you said Ever since you got the r7000 the problem started. Also try FW V1.0.4.30 after that I give up.
MrScrubsy
Oct 31, 2016Aspirant
No, I only found out that not having anyone connected to the Wifi will improve my connection. I'd like to find out as to why that is and fix it if possible, because people are always connected to the Wifi in this house...
Retired_Member
Nov 01, 2016If the other users are using Bandwidth intensive programs like streaming or downloading torrents as an example AND your ISP PIPE meaning DL & UL are insufficient those lags and spikes WILL continue.
I've asked several times for you to post a screen shot of a test which I gave up on after your last response. You unknowingly posted two identical link which USE cookies and shows a History of test MADE by who ever goes to the the site, The link shows MY history of test Not yours, because of cookies
Test again, press "FN & Prt SC" key to capture test, open paint select PASTE, Crop to include test results ONLY...insert picture in post.........................
- MrScrubsyNov 01, 2016Aspirant
Sorry Searay, I saw the "share with others" on the site and presumed that was the way it was supposed to be shown. Hopefully this works.
- MrScrubsyNov 03, 2016Aspirant
Changing the firmware to what you suggested seems to have made a vast difference and improvement so far. Thanks for the time and help, very much appreciated.
- Retired_MemberNov 03, 2016
You're welcome, Good News!
