MrScrubsy
Oct 25, 2016Aspirant
Packet loss during gaming with wired connection
Hello, Ever since our family has bought the R7000 I have noticed severe packet loss with a wired connection in gaming. Wifi has no issues with connection with at least 4 devices always connected. Th...
- AnonymousNov 01, 2016
Here's mine using WIFI
I think yours could be better seeing it's a wired test correct? The test MEANS Nothing when other users are using network. It Only gets worse.
I meant to suggest earlier that you hook up old router seeing how you said Ever since you got the r7000 the problem started. Also try FW V1.0.4.30 after that I give up.
MrScrubsy
Nov 01, 2016Aspirant
Sorry Searay, I saw the "share with others" on the site and presumed that was the way it was supposed to be shown. Hopefully this works.
Anonymous
Nov 01, 2016Here's mine using WIFI
- MrScrubsyNov 03, 2016Aspirant
Changing the firmware to what you suggested seems to have made a vast difference and improvement so far. Thanks for the time and help, very much appreciated.
- AnonymousNov 03, 2016
You're welcome, Good News!
