Jas0n1
Jun 06, 2016Aspirant
Packet loss during gaming
Hey all. I'll start off by saying that my knowledge of networking is very poor so I'd appreciate if you could help me in as simple form as possible. About close to a year ago I was having si...
- Jun 07, 2016
You should always reset after a firmware flash. Then reconfigure by hand and NOT from loading a configuration file. Try running with defaults if that will work for you. Recommend you reserve all your devices IP addresses.
Jas0n1
Jun 07, 2016Aspirant
Thanks for the reply James.
I decided to pull the trigger and upgrade the firmware last night as the packet loss is quite irritating with no success. It initially seemed to be better with packet loss going back to 0% for the first 2-3 minutes or so but it went back to normal.
At this point I am considering resetting the router - could this be useful at all here?
Thanks.
LeeH
Jun 07, 2016Prodigy
- Jas0n1Jun 07, 2016Aspirant
Thank you.
Ive done a reset and plugged in the log in details manually and so far so good - all packet loss seems to be gone!
May I ask why this happens in the first place? and is it expect to run a reset every time I experience packet loss?
Thanks again for all the help.
