Purp1eLemon
Nov 26, 2021Initiate
Packet loss on R9000
I have a Netgear R9000, and I am getting frequent packet drops on all devices across my LAN. I cannot connect to the Internet with HTTP or Xbox Live gaming service when I am experiencing a dropped co...
Nov 27, 2021Guru - Experienced User
2 things to try.
1. disable qos. It isn't recommended at speeds over 250mbps.
2. enable IPv6.
then reboot your router and the devices connected to it.
Try that for a bit and see how it works.
- Purp1eLemonNov 27, 2021Initiate
Thank you for the response.
My Internet connection cleared up by itself. There have been no packet drops within the last 12 hours. I hate Comcast.
However, I disabled QoS on the router as suggested, and changed the IPv6 Internet Connection Type to Auto Config. Just to be safe.
Thank you for your help.
