route123
Sep 13, 2021Aspirant
parent control doesn't work any more
Hello,
parent control in my router worked all the time till a couple of days ago.
nothing is chagned for the device except I changed from netgear modem to xfinity cable modem recently. I am not sure if it is related or not.
I checked the DNS servers are correct:
208.67.222.123
208.67.220.123
the parent control in opendns login is set as Moderate.
Any suggestions to fix the problem?
1 Reply
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalGood Luck.
