Jchoq
Nov 27, 2022Follower
Password recovery forgot answers to admin questions
I have an R8000 Nighthawk router that I had to reset because it would not accept the password and when I attempted to reset it I don't remember the answer to one of the questions. After resetting the router I was able to login with the default password. I then reloaded a saved configuration file to restore my settings. Now again it will not accept the password because I guess it put back the old settings. Any ideas?
1 Reply
- KitsapMaster
Jchoq wrote:I have an R8000 Nighthawk router that I had to reset because it would not accept the password and when I attempted to reset it I don't remember the answer to one of the questions. After resetting the router I was able to login with the default password. I then reloaded a saved configuration file to restore my settings. Now again it will not accept the password because I guess it put back the old settings. Any ideas?
Nothing short of performing the firmware default reset again and configuring your R8000 from scratch. Do not import your previous configuration.
