GypsyBluebell
Oct 29, 2020Aspirant
Password reset for Nighthawk AC1900 WiFi Range Extender
I don't have the paperwork that came with my WiFi Range Extender (I think hubby threw it out with the box) so I don't know the password. How can I find out the password or reset the password?
- Nov 07, 2020And you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password
Oct 29, 2020Guru - Experienced User
You can find manuals, firmware, and install guides here:
https://www.netgear.com/support/product/ex7000
to reset, push and hold reset for 7-15 seconds while its powered on.
that'll get you back to the defaults.
GypsyBluebell
Nov 06, 2020Aspirant
Thank you however I am still unable to reset the password for my WiFi Extender.
- plemansNov 06, 2020Guru - Experienced User
Which password?
The wifi password or the login to the gui?
Did you push and hold reset for 7-15 seconds while it was powered on? the lights should change.
What are the led's on it doing?
- GypsyBluebellNov 06, 2020AspirantHi, I'm wanting to reset the password for the initial connection to the extender as I am setting it up without knowing what the default password is.
- plemansNov 07, 2020Guru - Experienced UserAnd you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password
- tommieDec 03, 2020Aspirant
Hiw does one change the wifi password? I have changed the password for the wifi router and must now them for the extenders. This is an EX7000. Thank you
