GypsyBluebell
Oct 29, 2020Aspirant
Password reset for Nighthawk AC1900 WiFi Range Extender
I don't have the paperwork that came with my WiFi Range Extender (I think hubby threw it out with the box) so I don't know the password. How can I find out the password or reset the password?
- Nov 07, 2020And you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password
Nov 06, 2020Guru - Experienced User
Which password?
The wifi password or the login to the gui?
Did you push and hold reset for 7-15 seconds while it was powered on? the lights should change.
What are the led's on it doing?
GypsyBluebell
Nov 06, 2020Aspirant
Hi, I'm wanting to reset the password for the initial connection to the extender as I am setting it up without knowing what the default password is.
- plemansNov 07, 2020Guru - Experienced UserAnd you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password- GypsyBluebellNov 07, 2020AspirantI don't know what GUI is, however you have provided the password. Thank you
