GypsyBluebell
Oct 29, 2020Aspirant
Password reset for Nighthawk AC1900 WiFi Range Extender
I don't have the paperwork that came with my WiFi Range Extender (I think hubby threw it out with the box) so I don't know the password. How can I find out the password or reset the password?
- Nov 07, 2020And you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password
GypsyBluebell
Nov 06, 2020Aspirant
Hi, I'm wanting to reset the password for the initial connection to the extender as I am setting it up without knowing what the default password is.
Nov 07, 2020Guru - Experienced User
Default login info:
login: admin
password: password
Default login info:
login: admin
password: password
- GypsyBluebellNov 07, 2020AspirantI don't know what GUI is, however you have provided the password. Thank you
