philkoz
Jan 20, 2021Follower
password reset netgear
how do i rest my wifi password if i lost it. my modem serial number is 28t30c75052b8 product is wgr614v10
- No1MportntLuminary
You will need to to a factory reset on your router.
You can hardwire into the router and access it using the browser. That'll let you view/change the ssid/password without needing to factory reset it (provided you know the router login info)
If you do need to reset it, push and hold reset for 7-15 seconds while its powered on.
