Orbi1canorbi
Aug 08, 2021Initiate
Password reset
I am trying to reset my password. Each time I try I get all the question right and click next. Send me to the login and starts the reset password process again. It appears to be stuck in a loop.
Aug 08, 2021Guru - Experienced User
If you don't know the answers or didn't set them up, then your only option to get back into the router would be to factory reset the router.
Push and hold reset for 7-15 seconds while powered on.
Then reinstall the routerl
- Orbi1canorbiAug 09, 2021InitiateSolved
Tried from my PC and it all worked well. Clearly doesn’t work from phone or tablet.
