RangerZ
Nov 10, 2024Aspirant
PC Looses Network Connection
I have a Dell Precision 3460 PC (Intel 1219-LM, WIN 11Pro) which for about 10 days now seems to loose it LAN connection after 15-30 minutes. I stuck in an ASUS Wireless adapter, which works better, b...
RangerZ
Nov 11, 2024Aspirant
The failure of the LAN adapter occurred prior to connecting the ASUS wireless.
The ASUS was added only to test if the issue was the LAN Hardware, expecting that if it did not fail it was the Intel 1219-LM hardware.
As both adapters fail with similar results, though different time frames, I expect it's software. As the computer does not fail on a different network, I expect it's some type of communication issue with the router, but in my decades of doing this, not seen anything like it.
Nov 11, 2024Guru - Experienced User
Is this the only PC that does this?
Might try a factory reset on the router and setup from scratch with a wired PC:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
