RangerZ
Nov 10, 2024Aspirant
PC Looses Network Connection
I have a Dell Precision 3460 PC (Intel 1219-LM, WIN 11Pro) which for about 10 days now seems to loose it LAN connection after 15-30 minutes. I stuck in an ASUS Wireless adapter, which works better, b...
Nov 11, 2024Guru - Experienced User
Is this the only PC that does this?
Might try a factory reset on the router and setup from scratch with a wired PC:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
RangerZ
Nov 11, 2024Aspirant
Thanks for the links.
I have a working OpenVPN set up running on this with a couple of clients, so I think I am going to try a few more basic things like rebooting with out the PC connected, killing the Reserved IP, etc. and try to make it forget about the client.
I think I will also try killing the static lease on the PC for now.
There also is a firmware upgrade, and I probably have a backup of the config I could try to restore.
Unfortunately it's probably not going to be until the weekend.
- FURRYe38Nov 11, 2024Guru - Experienced User
đ
