LastNightsGrime
Dec 22, 2021Follower
Persistant Router Lag
This router seems to alway be lagging whether I'm hardwired or on wifi. Every speedtest I run says I'm getting about 195 Mbps down and 6 Mbps up. However, the actual performance is nothing like that....
Dec 23, 2021Guru - Experienced User
Why do you say its lagging?
Details are key because you're saying your tested speeds are fine but then saying you're getting lag.
Whats getting lag?
How are you testing it?
