al3k4t
Mar 19, 2022Aspirant
Philips Hue v 4 orange light R7000 and wifi drops randomly
Been experiencing wifi randomly drops with bridge connected. I am not at all tech savvy so here it goes hope you can help. Provider has confirmed physically etc that internet is working. Modem also ...
Mar 19, 2022Guru - Experienced User
a few more details are needed.
1. what firmware is on the router?
2. what modem is it connected to (model)?
3. what has a "orange" light. The hue bridge isn't gigabit so if the ethenet port light is orange/amber, thats to be expected.
4. does all wifi go down or just the 2.4ghz?
- al3k4tMar 19, 2022Aspirant
1. what firmware is on the router? v1.0.11.126
2. what modem is it connected to (model)? MB86003. what has a "orange" light. The hue bridge isn't gigabit so if the ethenet port light is orange/amber, thats to be expected. noted. when bridge is connected to either ethernet port 1-4 corresponding light on router is orange.
4. does all wifi go down or just the 2.4ghz? all wifi goes down. not able to find it when doing searches for wifi on phone for instance. router and modem will look unchanged however.
Keep in mind. We’re members of the public helping out on our own time. completely understood. i work around this issuedaily but looking for a best solution in time.- plemansMar 20, 2022Guru - Experienced User
when the wifi is down, what does it show in the status page on the router for the wifi?
Are the wifi led's on?
What happens if you change which channels the wifi is broadcasting on?
