ImSarita's avatar
ImSarita
Phone ports not working
Every other light except Phone 1 and Phone 2 are lit.
Can this problem be fixed?
  • Everything's working but the phone ports?
    Who's your isp?
    Have you contacted them? Its their provisioning that allows those to function
  • plemans's avatar
    Who's your isp?
    • ImSarita's avatar
      ImSarita
      Thank you! ISP is Xfinity. I'll be calling them in the a.m.
  • michaelkenward's avatar
    michaelkenward
    You are asking about features specific to the Voice bit of a cable modem/router. People who own those may not hang around in this section for Nighthawk WiFi Routers
    For more advice from people whop use those things, try this section:
    Cable Modems & Routers
